Activity Forums Adobe After Effects program crash after updating after effects
  • program crash after updating after effects
    Posted by Mozwald on January 6, 2007 at 5:38 am
    i just ran an update for after effects 7, and as the start up screen was scanning and loading plug-ins, it slowed down to a crawl then my computer became extremely sluggish. Anyone know what would cause this? Ive had the slow plugh-/scan thing happen before, randomly at times. Im confused.
    Brian Charles replied 19 years, 8 months ago 3 Members · 5 Replies
  • Mylenium
    January 6, 2007 at 10:03 pm
    Maybe one of your plugins is not 100% compatible to AE 7. Try to remove all third-party plugins and see if the problem is persistent or goes away.
    Mylenium
    [Pour Myl
  • Brian Charles
    January 6, 2007 at 11:32 pm
    Have you tried resetting the preferences file?
    When you start After Effects hold down the Shift+ Option + Command key on a Mac or the Shift+ Alt + Control key in Windows.
    The OpenGL plugin is know to cause startup crashes, try removing it and then re-launching After Effects.
  • Mozwald
    January 6, 2007 at 11:41 pm
    would this be the same as removing the “use openGL when availble” option in rendering?
  • Mozwald
    January 7, 2007 at 12:08 am
    i just installed it, so there were no plug-ins.
  • Brian Charles
    January 7, 2007 at 5:21 pm
    No you must drag the OpenGl Plug in out of the plug in folder.
