Activity Forums Adobe Premiere Pro Production Premium Installation Fail
  • Production Premium Installation Fail
    Posted by Kyle Martens on August 30, 2015 at 8:20 pm
    I’ve been trying to re-install CS 5.5 on my computer (PC with windows 8). It fails on the third disk and won’t install AE, Premiere, etc. The following is the error transcript, do any of these provide a tip as to what I need to undertake to correct the failure?
    Many thanks,
    -KM
    Exit Code: 6
    ————————————– Summary ————————————–
    – 17 fatal error(s), 61 error(s), 46 warning(s)
    ———– Payload: {D1B83970-7269-48BE-8B0E-5120D9327E52} Adobe Player for Embedding 3.1 3.101.0.0 ———–
    ERROR: DB001: Cannot open data base file G:\Adobe CS5_5\payloads\AdobeAPE3.101-mul\Install.db
    FATAL: DB005: sqlite prepare: ‘SELECT * FROM Property WHERE propertyName=’TotalSize” (21) disk I/O error
    WARNING: DS007: TotalSize property not set in data base
    FATAL: DB005: sqlite prepare: ‘SELECT * FROM Assets’ (21) disk I/O error
    ERROR: DB008: Cannot fetch entries from Assets table
    ———– Payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 9.9.0.0 ———–
    FATAL: DB005: sqlite prepare: ‘SELECT * FROM Property WHERE propertyName=’TotalSize” (10) disk I/O error
    FATAL: DB005: sqlite prepare: ‘SELECT * FROM Assets’ (10) disk I/O error
    ———– Payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 2.0.0.0 ———–
    WARNING: DF029: ARKServiceControl::StartService: Service not started/stopped SwitchBoard. Current State: 0 Exit Code: 0 Service Specific Exit Code: 0(Seq 1)
    ———– Payload: {42774483-D33C-46F7-8B20-FD0B1A3DAC25} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 ———–
    WARNING: DW036: Payload cannot be installed due to dependent operation failure
    ———– Payload: {6548A7DA-770A-4BCD-A6ED-719CC7B6FD1B} Adobe Media Encoder CS5.5 X64 5.5.0.0 ———–
    ERROR: DB001: Cannot open data base file G:\Adobe CS5_5\payloads\AMECore5.5All_x64\Install.db
    ———– Payload: {CE75F5DB-8CA3-4E84-A30E-AF9160006105} Adobe Player for Embedding x64 3.1 3.101.0.0 ———–
    FATAL: DS003: Cannot extract ‘G:\Adobe CS5_5\payloads\AdobeAPE3.101_x64-mul\Assets1_1.zip’ to ‘C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{CE75F5DB-8CA3-4E84-A30E-AF9160006105}’. Error: Error 23 Data error (cyclic redundancy check).
    ———– Payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 9.9.0.0 ———–
    FATAL: DS003: Cannot extract ‘G:\Adobe CS5_5\payloads\AdobePDFL9.9_x64-mul\Assets2_1.zip’ to ‘C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{17C6080E-F475-4B49-A30C-EEB85673E999}’. Error: Error 23 Data error (cyclic redundancy check).
    ———– Payload: {EF45880C-DD84-46C3-A054-0BC5F76A6BBE} Adobe Photoshop CS5.1 Support 12.1.0.0 ———–
    ———– Payload: {90BF0360-A1DB-4599-A643-95AB90A52C1E} Microsoft_VC90_MFCLOC_x86_x64 1.0.0.0 ———–
    ———– Payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation 1.0.0.0 ———–
    ———– Payload: {7202D4A7-F7E6-4e7a-B77D-7B1C4E8B5CA6} Adobe Flash Player 10 ActiveX 10.0.0.0 ———–
    ERROR: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\KYLEMA~1\AppData\Local\Temp\InstallAX.exe, command: -install activex -msi
    ERROR: Install MSI payload failed with error: 1603 – Fatal error during installation.
    MSI Error message: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\KYLEMA~1\AppData\Local\Temp\InstallAX.exe, command: -install activex -msi
    ———– Payload: {43A1C48E-3E50-410e-951C-E17A66BBF824} Adobe Flash Player 10 Plugin 10.0.0.0 ———–
    ———– Payload: {EB186BF2-0A84-40A2-B794-0326D3DF9973} AdobeColorVideoProfilesCS CS5.5 3.1.0.0 ———–
    ———– Payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 5.0.0.0 ———–
    ———– Payload: {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1 1.0.0.0 ———–
    ———– Payload: {F3E41C2A-3A29-476D-9685-3F8055AF696A} CS5.5 Production Premium 5.5.0.0 ———–
    ———– Payload: {D8CCCF4C-C227-427C-B4BE-736657D2AB7E} Adobe Flash Catalyst CS5.5 1.5.0.0 ———–
    ———– Payload: {F9F276DA-9EC6-492C-AF58-F27C5EC19D66} Adobe Photoshop CS5.1 English Language Pack_x64_AdobePhotoshop12-en_US_x64 12.1.0.0 ———–
    ERROR: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\KYLEMA~1\AppData\Local\Temp\InstallPlugin.exe, command: -install plugin -msi
    MSI Error message: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\KYLEMA~1\AppData\Local\Temp\InstallPlugin.exe, command: -install plugin -msi
    ERROR: DW050: The following payload errors were found during install:
    ERROR: DW050: – Adobe ExtendScript Toolkit CS5.5: Install failed
    ERROR: DW050: – GermanSpeechAnalysisModels: Install failed
    ERROR: DW050: – Adobe Premiere Pro CS5.5 Support: Install failed
    ERROR: DW050: – AdobePDFL x64 CS5: Install failed
    ERROR: DW050: – Adobe Illustrator CS5.1: Failed due to Language Pack installation failure
    ERROR: DW050: – Adobe Encore CS5.1: Failed due to Language Pack installation failure
    ERROR: DW050: – ItalianSpeechAnalysisModels: Install failed
    ERROR: DW050: – Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-en_US: Install failed
    ERROR: DW050: – Pixel Bender Toolkit: Install failed
    ERROR: DW050: – CSXS Story Extension: Install failed
    ERROR: DW050: – SpanishSpeechAnalysisModels: Install failed
    ERROR: DW050: – Adobe OnLocation CS5.1_AdobeOnLocation5.1en_USLanguagePack: Install failed
    ERROR: DW050: – Adobe Flash Player 10 Plugin: Install failed
    ERROR: DW050: – AdobeMotionPicture CS5.5: Install failed
    ERROR: DW050: – Adobe OnLocation CS5.1: Failed due to Language Pack installation failure
    ERROR: DW050: – Adobe After Effects CS5.5 Template Projects & Footage: Install failed
    ERROR: DW050: – Adobe Media Encoder CS5.5 X64: Install failed
    ERROR: DW050: – Adobe Flash Player 10 ActiveX: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5 Support: Install failed
    ERROR: DW050: – Adobe OnLocation CS5.1 Third Party Content Wrapper: Install failed
    ERROR: DW050: – KoreanSpeechAnalysisModels: Install failed
    ERROR: DW050: – Adobe Story: Install failed
    ERROR: DW050: – Adobe Flash CS5.5_AdobeFlash11.5-en_USLanguagePack: Install failed
    ERROR: DW050: – FrenchSpeechAnalysisModels: Install failed
    ERROR: DW050: – Adobe Premiere Pro CS5.5 Functional Content: Install failed
    ERROR: DW050: – AdobePDFL CS5: Install failed
    ERROR: DW050: – Adobe Encore CS5.1_AdobeEncore5.1en_USLanguagePack: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5: Failed due to Language Pack installation failure
    ERROR: DW050: – Adobe After Effects CS5.5 Presets: Install failed
    ERROR: DW050: – JapaneseSpeechAnalysisModels: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5 Third Party Content Wrapper: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5_AdobeAfterEffects10.5en_USLanguagePack: Install failed
    ERROR: DW050: – ph: Install failed
    ERROR: DW050: – AdobeColorVideoProfilesAE CS5.5: Install failed
    ERROR: DW050: – AmericanEnglishSpeechAnalysisModels: Install failed
    ERROR: DW050: – Adobe Player for Embedding x64 3.1: Install failed
    ERROR: DW050: – HIL Help Search: Install failed
    ERROR: DW050: – Adobe Player for Embedding 3.1: Install failed
    ERROR: DW050: – Adobe Flash CS5.5: Failed due to Language Pack installation failure
    ERROR: DW050: – SiteCatalyst NetAverages CS5.5: Install failed
    ERROR: DW050: – Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack: Install failed
    ERROR: DW050: – Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-mul: Install failed
    ERROR: DW050: – Adobe Premiere Pro CS5.5: Failed due to Language Pack installation failure
    ERROR: DW050: – Adobe Encore CS5.1 Library: Install failed
    ERROR: DW050: – InternationalEnglishSpeechAnalysisModels: Install failed
    ERROR: DW050: – Adobe Premiere Pro CS5.5_AdobePremierePro5.5en_USLanguagePack: Install failed
    Kyle Martens replied 11 years ago 2 Members · 2 Replies
  • Ann Bens
    August 31, 2015 at 11:04 am
    https://helpx.adobe.com/creative-suite/kb/errors-exit-code-6-exit.html
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Kyle Martens
    September 8, 2015 at 3:14 am
    Finally had time to troubleshoot further. I wasn’t able to find any additional documentation or successfully implement the strategies detailed in the link. Extremely frustrating…
