Activity Forums VEGAS Pro Production Assistant – Template issues
  • Production Assistant – Template issues
    Posted by Al Bergstein on October 7, 2010 at 3:14 am
    Hi, new to PA, and working primarily in Panasonic AVCHD (hmc150), and Canon MOV converted to AVI. Want to create a template, since none is shipped in 1080×29.97. I assume I create a project in Vegas, set all properties correctly for the above inputs. Put in a title in front of a slug for media etc. Add a closing credits (do the blank slugs all need to be the proper length or will they expand to fit the media? I also assume I don’t check the box (adjust source media to fit the project)?
    If this is all correct, I try and go to save this VEG and there is no Templates folder under the location that the documentation says it should be. I have no templates folder under the
    C:\Program Files (x86)\Sony\Production Assistant 1.0
    I have CONFIGS ICONS and PRESETS folders. Should I just make a template folder? Where are the 3 templates I have being pulled from?
    Also, I’m running Windows 7 64bit. Is PA a 32 bit app? There’s nothing in the normal C:Programs Files for it so I assume that’s true.
    Alf
    Al Bergstein replied 15 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
