Activity › Forums › Adobe Premiere Pro › Producing multi-clip effects like “24”
Posted by Daniel Levy on February 9, 2009 at 1:42 pmI’m using CS4.
Could anyone offer suggestions for producing a multi-clip final image like is done on the TV show “24”?
I’ve seen similar done with “Lightwave”, using multiple projection planes in the same scene, but that requires a lot of rendering.
Is there a simple plug-in that offers such capability within CS4?
Daniel Levy replied 17 years, 7 months ago 4 Members · 11 Replies -
Eddie Lotter
February 9, 2009 at 2:39 pm -
Chris Buttacoli
February 9, 2009 at 7:13 pmEvery video clip on the timeline has a motion setting in its effect controls palette. Inside that drop down is a scale parameter and a position parameter. By layering clips on top of each other and adjusting those parameters for each, you will achieve the look you are going for.
Chris Buttacoli
February 9, 2009 at 7:18 pmWow, never saw “24”! Jack Bauer may come after YOU next season.
Daniel Levy
February 10, 2009 at 3:12 amThanks. I’ll work in it tonight.
I really appreciate all the help on this site!
Daniel
Raj Swahali
February 11, 2009 at 5:33 pmHere is a specific video tutorial that even mentions trying to emulate the 24 type pip effect.
https://blogs.adobe.com/genesisproject/2008/08/adobe_beginner_classes_episode_7.html
Eddie Lotter
February 11, 2009 at 8:20 pmThanks for posting. That tutorial is among the tutorials I linked to in reply #1. 🙂
Cheers
Eddie -
Daniel Levy
February 11, 2009 at 10:34 pmThanks! Looks slick and relatively easy.
BTW, when I place several video streams in a single view, the preview monitor plays back kind of choppy. Is that cured once one renders the final output?
Daniel
Eddie Lotter
February 11, 2009 at 11:35 pmIt should be, yes, however some people have reported that even their exports are not smooth.
I suggest you do a test to see what happens on your system.
Cheers
Eddie
