Activity › Forums › Adobe After Effects › Producing circle shaped particles
  • Producing circle shaped particles
    Posted by Amit Zinman on June 8, 2009 at 8:45 pm
    Hi all,
    I want to produce a lot of circles, and I mean a LOT. Particular could do this but I want them to be colored circles within circles with some animation the way you would do with the Circle effect.
    Any ideas?
    Amit
    Stuart Elith replied 17 years, 3 months ago 3 Members · 2 Replies
  • David Bogie
    June 8, 2009 at 9:40 pm
    Foam.
    bogiesan
  • Stuart Elith
    June 9, 2009 at 1:05 am
    Or you could create a little comp that has the animation and look that you want, and use it as a custom particle with particular. This would probably give you the most customisation both from the particle aspect (since Particular has great controls and options) and also as it would let you do anything you like to get the circles looking good. You may want to render out your particle comp so that it’s not calculating them all as it goes, if things start getting heavy.
