Activity › Forums › Adobe After Effects › Producing a demo reel using 2 different comp sizes
  • Producing a demo reel using 2 different comp sizes
    Posted by Gino Guarnere on December 29, 2006 at 7:42 pm
    Hello all!
    I’m attempting to make my first demo reel, and I have AE compositions I’d like to include that are both HDV compositions as well as standard NTSC comps. Of course, when I render these out as Quicktimes (with the intention of bringing them into Final Cut Pro to cut), I’ll have an issue as FCP doesn’t deal with different resolutions on the same timeline.
    Having said that, should I scale up the NTSC comps or scale down the HDV comps (or neither)? Basically, I don’t want to recreate the compositions, as considerable time went into them at the resolutions at which they were composed.
    Thanks in advance!
    Gino
    https://www.pixeldustfilms.com
    Illya Laney replied 19 years, 9 months ago 3 Members · 4 Replies
  • Iancorey
    December 29, 2006 at 7:52 pm
    I think you know that the answer would be to scale your HDV down and letterbox it. If this demo is for the web, the loss of resolution and frame size won’t be so much of an issue.
  • Gino Guarnere
    December 29, 2006 at 8:08 pm
    Hi Ian,
    The piece will hopefully end up on DVD, but yes, it will certainly live on the web.
    Could you describe how to scale down the HDV footage and letterbox it? (Not sure if I just resize the comp or what).
    Thanks, Ian, for the fast reply.
    Best,
    Gino Guarnere
  • Gino Guarnere
    December 30, 2006 at 12:10 am
    Yeah, Dave, I was thinking about something similar: I was planning on parenting my 16×9 footage to a null then scaling down the entire comp (pretty similar to what you described). Of course, the opposite will work as well. I’ll play with a few iterations of this and see what turns out to be the path of least resistance…
    Thanks again, all!
    G
  • Illya Laney
    December 31, 2006 at 5:47 am
    Why don’t you just letter box it and then resize the footage when you’re rendering it out? That or just precomp it and resize it to match your new composition size.
