Producer system requirements?
Posted by Matt Short on January 19, 2007 at 7:21 pmWhat are the system requirements to run Producer?
Arthur Dent replied 19 years, 8 months ago 3 Members · 3 Replies -
Floh Peters
January 19, 2007 at 7:31 pmIt depends on what you want to edit. SD does require less performance and throughput than HD; “easy” codecs (like DV or Unocmpressed) require less CPU-power than more render-intense codecs (like Media 100 i or even legacy 640*480/768*576 Media). I did some editing on a G4 PowerBook (1.5GHz), which worked but had not really the best response. I
Matt Short
January 19, 2007 at 7:34 pm[Floh] “If you are wondering if it will perform okay on a CPU you own, I
Arthur Dent
January 19, 2007 at 8:22 pmMedia 100 told me, they recommend a minimum 1.67 Power book with 2 gig ram – but the application is optimized for the G5.
I’ll bet a dual 1.42 G4 Tower or better.
A.D.
