Activity › Forums › Maxon Cinema 4D › Procedural text animation in Cinema 4D with Sketch and Toon
  • Procedural text animation in Cinema 4D with Sketch and Toon
    Posted by Jefferson Lopez on December 26, 2017 at 2:35 am
    Hi Guys, I’m new with cinema 4D and I’m needing some help.
    Basically, I’m trying to add the sketch and toon post effect to a Motext animated with an effector (Plain).
    What I’m getting are some extra outlines just next to the text I want.
    Project file: 12013_text3d1.c4d.zip
    Jim Scott replied 8 years, 9 months ago 3 Members · 2 Replies
  • Michael Goldberg
    December 26, 2017 at 4:02 pm
    Looks like you just need to adjust the shading in your S & T tag.
    I often render sketch and toon over white, and so I change the shading to background with a white background. The other way to go is to create a transparent material for your text (alpha channel set to black), and set the shading to none. This will apply the transparent material on the text, but render out the lines.
    Mike
  • Jim Scott
    December 26, 2017 at 4:12 pm
    I’m sorry, but I’m not seeing any extra outlines next to the letters, either in the main png output (see below), or any of the multipasses. Or maybe I’m missing something…? Could you provide a screenshot of your rendered image showing the outlines?
    Edit: Or are you referring to the black outlines on the letters themselves… and if so, does Michael’s suggestion address your issue?
