Activity › Forums › Blackmagic Design › Proc Amp on Decklink SP – In and Out?
Posted by Kai Whittaker on September 26, 2005 at 2:10 pmDoes the Proc Amp on the Decklink control panel affect the input AND the output? Or does it only affect input?
Thank you,
Kai
Kai Whittaker replied 20 years, 11 months ago 3 Members · 5 Replies -
Kai Whittaker
September 26, 2005 at 2:14 pmThe reason I’m asking is becaused the output level on my Decklink SP is a little low. I’m trying to find a way to boost the ouput from the computer, without having to adjust the footage coming in or having to put a proc amp on my whole sequence.
Thank you!
Kai
Luke Maslen
September 27, 2005 at 4:51 amHi Kai,
Proc Amp is only for use with the input during capture. What are you capturing from and to what are you outputting?
Regards,
Luke Maslen
Blackmagic Design -
Kai Whittaker
September 29, 2005 at 4:27 pmI’m capturing stuff from two decks:
Sony PVW-2800
Sony J-3I’m outputting to either a Digibeta Deck from Sony or to the PVW-2800.
My main problem is whitie, and chroma levels, I’m making progress with the white level by making tiny adjustments to my input proc amp gain. My system is capturing and laying back white and black levels properly. Chroma levels are another story. When I render something in After Effects, then output it in Final Cut Pro, I get illegal chroma levels. I had several tapes refused technical approval at PBS in the States recently and I wondered if there was somethign else I could change about my system to clamp all my chroma at 100.
I could use the NTSC safe plugin in FCP, or use the “Safe Colors” buttons in some of the AE plugins I use. Maybe I’m, missing a step in my workflow…
Do you have any ideas?
Dave Beaty
October 4, 2005 at 2:46 amOne suggestion for AE is to use a top most adjustment layer and apply the Broadcast Colors filter to the adjustment layer. Having a vectorscope set up to monitor AE output makes it easy to see. The levels filter will also help with black and white levels in AE. HTH
Dave
Kai Whittaker
October 25, 2005 at 8:11 pmI have always eanted a real one… but software is all i can afford for now…
I’m going to go check on eBay just for fun.
Thanks for the pointers.
Kai
