Activity Forums Apple Final Cut Pro Legacy probs using DV CAMERA for playback…
  • probs using DV CAMERA for playback…
    Posted by Barb on July 15, 2005 at 8:11 pm
    I’m working with FCP4, and usually I can use my DV CAMERA w/FIREWIRE as my deck for capture, and to go to VHS player for print(by hooking RCA cables up from my camera)… Recently, I can log and capture, no problem; but my camera doesn’t seem to be getting the OUT from FCP. I should be able to see things when I play items in the time line, but also it should work when I print to Video.. but nothing happens. PLEASE HELP!
    Chris Vicari replied 21 years, 2 months ago 3 Members · 4 Replies
  • Michael Peele
    July 16, 2005 at 1:54 am
    Make sure this menu item is turned on:
    View->External Video->All Frames
    or you can hit Apple+F12
    Make sure your deck/camera is on when starting FCP.
    Make sure your Video Playback setup is correct in Audio/Video Settings.
    Mike
  • Chris Vicari
    July 16, 2005 at 6:59 pm
    I have the same problem and so does a buddy of mine. I’m puzzled.
    I have a G5 powermac with final cut studio 5, Tiger and a DCR-pc1000 for a deck.
    When I playback the timline I cannot see video on the monitor. When I log and capture it shows up.
    I’m missing somthing, just not sure what.
  • Barb
    July 16, 2005 at 11:25 pm
    maybe try checking if the aduio and video playback settings are the same… in AV SETTINGS, AV DEVICES. if they are try changing them, and them change ’em back. i think that solved my prob.
  • Chris Vicari
    July 19, 2005 at 11:47 pm
    I’ve been fussing with the settings for some time now. Back and forth, nothing seems to make it work.
