Activity Forums VEGAS Pro Problems Zooming In…
  • Problems Zooming In…
    Posted by Seth Kopchu on February 1, 2008 at 11:25 pm
    I’m running Sony Vegas 6.0, and is it possible to, in the Event Pan/Crop menu, to zoom in on a desired location on the image you have in the track, and then zoom out from the point you just made in that menu to eventually reveal the whole image, without the use of putting in the zoom transition effect?
    Thanks for those who reply.
    Edward Troxel replied 18 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Don Bloom
    February 2, 2008 at 12:07 am
    Yes. At the beginning of the event, in the P/C window, set your point you want the zoom to be at, then move down the timeline in the P/C window and click in a new keyframe by ‘right clicking’ and setting to ‘restore’. This will set the pan/crop back to the original size of the event.
    HTHs
    Don
  • Seth Kopchu
    February 2, 2008 at 2:46 am
    When you say set the zoom that I want, do you mean manually click the jpeg picture and then open up the Pan/Crop window, and click around and zoom it in until I got it, then proceed to do what you said? Beause I create the new keyframe, but when I right click, there is no restoring.
  • Mike Kujbida
    February 2, 2008 at 3:12 am
    What Don means is to move the cursor (in the Pan/Crop window) to the point that you want the zoom to end and then right-click in the main Pan/Crop window itself (not on the timeline) and select Restore.
    Make sense now?
  • Seth Kopchu
    February 2, 2008 at 3:46 am
    Actually, I should correct myself:
    I don’t want to restore the picture back – I want take it, zoom in a certain part, and then slowly pull back away from the zoomed in poing back to where it then restores itself. Do I need a plugin to do that or is it already on Vegas 6?
  • Don Bloom
    February 2, 2008 at 3:56 am
    no plugin needed. Just use keyframes in the tileline in the Pan/Crop window and to do the pull out simply set a keyframe where you need it and then resize the image.
    Play around with it a bit, you can’t hurt anything and I think you’ll find what you need in the pan/crop window woth keyframes.
    Don
  • Mike Kujbida
    February 2, 2008 at 4:20 am
    Seth, there seems to be a communication problem as what Don suggested is the way to do it but, for whatever reason, you’re not understanding it.
    Vegas can do this very easily without any plugins so let’s go through this step by step and see if we can get you going on it.
    #1. Import a picture and drag it up to the timeline.
    The default image length is 5 sec.
    If you need it to be longer, place the cursor at the right-hand edge of the image and, while holding the left mouse button, drag it longer.
    For this example, I’d suggest making it 10 sec. long.
    #2. Open the Pan/Crop window.
    Move this window over so that you can see the Preview window in Vegas at the same time.
    The first frame is automatically a keyframe and any adjustments you make to the image will be the starting point so set the zoom on the image as desired. The “F” will be shrunk and positioned where you want things to start.
    #3. Now click the cursor so that it’s at the end of the the timeline.
    Move up to the center of the Pan/Crop window, right-click on the image and select “Restore”.
    The “F” will now take up the entire image.
    That’s it. Close the Pan/Crop window and play it to see if you like the result.
    You may need to set the Preview window to Preview/Auto to ensure smooth playback of the zoom out.
    If the effect is not exactly what you wanted, open the Pan/Crop window again and adjust as required.
  • Edward Troxel
    February 2, 2008 at 2:29 pm
    You might want to look through Vol 1 #8 and Vol 2 #8 of my newsletters.
    Edward Troxel
    JETDV Scripts
