Activity Forums Adobe After Effects Problems withAlpha Channels from Cinema 4d to After Effects
  • Problems withAlpha Channels from Cinema 4d to After Effects
    Posted by Carlos Arreola on March 28, 2016 at 9:44 pm
    *I recently repost this thread but under the Cinema 4D section since I wasn’t sure if this was an Ae problem more than it was a Cinema 4D issue*
    I’m currently having issues trying to remove the black background from my composition and put it on an Ae composition. I already tried many combinations of rendering with almost no luck, but here’s the main one;
    Quicktime Movie – PNG and Animation – Millions of Colors+
    Alpha Channel – Checked
    Straight Alpha – Checked and Unchecked
    Once the file has been rendered and play it on quicktime it looks like this which what I’m looking for
    But when I open the file on Ae, it comes out like this
    I’m aware there are ways to remove the background on Ae effects but I can’t, the rendered file has black smoke.
    Walter Soyka replied 10 years, 5 months ago 3 Members · 5 Replies
  • Walter Soyka
    March 29, 2016 at 10:45 am
    Are those two screenshots showing the same frame? Can you render a PNG sequence and share a frame with us?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Vincent Halman
    March 30, 2016 at 9:01 am
    Hello Carlos,
    the best way to export cinema 4D video to after effects is to render your Cinema 4D animation as a PNG. Make sure to render all the frames. This way you’ll have a folder with alot of PNG files. (the many frames your animation has). Now you can create a png sequence in Adobe Premiere and export that as an Alpha quicktime video file. Hope this will help you out! If you dont get it or got any questions. In my latest video on Youtube I’m also exporting my project as with an alpha channel. Search ‘Detline’ on youtube and you’ll find it 😉
  • Carlos Arreola
    March 30, 2016 at 8:11 pm
    No, they’re different frames within the same video.
    Here’s more screenshots that I took.
    Here’s the intended graphic
    Here’s how it looks rendered as QT/ANIMATION/ALPHA CHANNEL/ALPHASTRAIGHT
    Here’s how it looks on Ae
    About the PNG sequence, do you want the render from C4D or from Ae?
  • Carlos Arreola
    March 30, 2016 at 8:25 pm
    Hey nice!
    However, it didn’t work :/. I got the same result.
  • Walter Soyka
    March 31, 2016 at 6:54 pm
    Are you doing any kind of post-effects in C4D? What do you see if you render a floating-point EXR?
    Walter Soyka
