Activity Forums Apple Final Cut Pro Legacy Problems with XDCAM Transfer en FCP 7
  • Problems with XDCAM Transfer en FCP 7
    Posted by Michel Steinberg on September 29, 2015 at 2:23 am
    Hello!
    I’m trying to export an MFX XDCAM HD422 file from my sequence using XDCAM Transfer but I keep getting the following error:
    Please check that the volume to which you are exporting is not locked or full. Error opening movie (while checking valid media time scale).
    I have more than 200 GB on the drive so that shouldn’t be the problem
    My sequence is set up as XDCAM HD422 1080p30 (I used progressive as I need to use huge fast motions in many clips)
    Someone got this error in the past? How can I fix it?
    Thanks!!
    Michel Steinberg replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
