Activity Forums Adobe After Effects Problems with watertank effects and ink drops.
  • Problems with watertank effects and ink drops.
    Posted by Kai Indvik on May 20, 2009 at 5:23 pm
    Hello!
    I am planning on releasing a toolkit fairly soon, but I’m running into some problems. I am filming some ink splatters, and then trying to key them out. However, around the edges of the ink, there is a wiggling. This is due to the keying. Is there any way to fix this? Because it effectively makes the clips unusable. Should I use a Matte Choker or something?
    My second question is, how do I film a watertank effect? I have a fishtank that I am using, but it’s not working out so well. I’m having problems extracting the ink. Any tips?
    Thank you so much
    Kai
    Golf is a good walk spoiled
    ~Mark Twain
    Kai Indvik replied 17 years, 2 months ago 5 Members · 5 Replies
  • Kirk Smith
    May 20, 2009 at 6:01 pm
    I’m just throwing this in there, so don’t think I really know what I’m talking about in any way.
    What I would try is putting a green or blue plastic sheet on the back side of the fish tank (is it a square one of round?) and then putting the camera right up the the glass. Make sure you’re properly focused where you need to be and try that. As long as the water is clean there should be no refraction or anything since you’re filming straight on.
    Is the camera you’re using a waterproofed one? If so then sticking it in the water might help, too.
    Like I said, I don’t really know what I’m talking about, this is just where I would start.
  • Kevin Camp
    May 20, 2009 at 6:54 pm
    i’m not sure how you’re set up, but i would shoot black ink on a white background, then generate a matte from that rather than ‘key’ the ink.
    a big advantage of this is you can work with just the luminance values of the clip and avoid the lower quality, more highly compressed components of the video signal. applying the tint effect will effectively extract just the luminance from the footage which is the cleanest channel to work with. then it’s just a matter of adjusting levels/curves and some rotoscoping to clean up any debris/lighting issues…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Michael Szalapski
    May 20, 2009 at 7:30 pm
    Kevin is very, very right. Black ink on a white background is a much better way to go. You can use black and white shots as a track matte in your NLE without even going into After Effects at all.
    The wiggling you are describing is due to the compression of dv footage. It’s got noise in it; that’s the nature of shooting without a great camera.
    What specific problems are you having with your tank shots?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • David Bogie
    May 20, 2009 at 7:37 pm
    There was a recent post on one of AE Tutorial sites about the effects wonks who shot Close Encounters of the Third Kind. Complete exposé about their tank effects. They used cold salt water floating on top of hot fresh water and then injected white latex paint (in various dilutions) between the two layers of water.
    It was much more complicated than that.
    I’ve shot lots of tank stuff but just with inks against white and white latex against black with various colored lights. It’s all about experimentation and lots of cleaning up. Never got into using fluids with different densities.
    bogiesan
  • Kai Indvik
    June 18, 2009 at 7:30 pm
    thanks for all of the answers!
    I eventually wound up using white in on a black background, in a darkroom. This fixed the problem of reflections I was having. Thanks again for the answers.
    ~Mark Twain
