Activity Forums VEGAS Pro problems with “vibrating” images
  • problems with “vibrating” images
    Posted by Larry Watts on May 10, 2007 at 5:46 pm
    We are always wrestling with images that vibrate (or flicker) during a zoom or move. Files that have too much resolution seem to be the worst. We often lower the resolution and apply a gaussian blur to fix the problem.
    It would be great to be able to fix all the images in some kind of batch routine.
    Is anyone aware of a way to do this?
    Even a sure fire step by step that could become an action would be good. (We could have interns do this)
    Surely someone has a better way than the laborious processing we are currently doing.
    Larry
    LSW
    Mary Waitrovich replied 19 years, 4 months ago 3 Members · 2 Replies
  • Edward Troxel
    May 10, 2007 at 6:05 pm
    [Larry Watts] “We often lower the resolution and apply a gaussian blur to fix the problem.”
    This is the typical method.
    [Larry Watts] “It would be great to be able to fix all the images in some kind of batch routine.
    Is anyone aware of a way to do this?”
    You could apply “Reduce Interlace Flicker” or add a blur effect to each. A really quick way is via a script.
    Edward Troxel
    JETDV Scripts
  • Mary Waitrovich
    May 10, 2007 at 8:37 pm
    lower the resolution to just as many px as you need to do any panning or zooming. As for batch processing, Photoshop can do it. Create an “action” then run the action on a folder or selected files.
    Mary Waitrovich
    UW-Madison
