Problems with Vegas
Posted by David Polovin on July 22, 2008 at 5:58 pmI still wasnt able to fix my rendering problem. I tried using different codecs and it still dark when i render the video. Unless i use uncompressed version.
Steve Rhoden replied 18 years, 2 months ago 3 Members · 3 Replies -
Steve Rhoden
July 22, 2008 at 6:15 pmI am not following your post David, What render problems are you referring to specifically?
Steve Rhoden
Creative Director
TNX EFFECTS STUDIOS. -
Allen Zagel
July 22, 2008 at 8:10 pmSteve
I think he’s refering to his previous post of July 11th.https://forums.creativecow.net/readpost/24/881588
Allen
ASX Media Group, Inc.
https://www.asxvideo.com -
Steve Rhoden
July 22, 2008 at 8:27 pmOK..OK…Thanks Allen.
David,
Sorry you have not arrived at a solid solution as yet for this
problem…Only thing that i would recommend you do then, is to
render out using the uncompressed format as you say which gives you
the best result….then place it back in vegas…and maybe reduce the contrast and brighten it up a bit and then render it out to the
format you ultimately desire.
Sorry i can’t suggest a better solution.Steve Rhoden
Creative Director
