Activity › Forums › RE:Vision Effects › Problems with Twixtor, making a clip longer
  • Problems with Twixtor, making a clip longer
    Posted by Tim Collins on September 10, 2011 at 7:54 am
    Hi there,
    This is my first time using Twixtor, and I have followed the Tutorial step by step, but I am having a problem after rendering my slowed down clips.
    I am using FCP7 and Twixtor 4.5
    I have a clip I need to slow down to 10%.
    I created a new sequence, copied in the clip 10 times, created another sequence and then I drug in the intermediary sequence to the new timeline.
    Here I opened the intermediary sequence in the viewer, applied the setting changes I wanted, (4 speed % key frames) and hit render.
    What is get is not a clip slowed to 10%, but instead a very slow clip that bounces back and forth, ‘ping ponging’ (for lack of a better term). It still progresses forward, but not smoothly at all.
    I hope my description is understandable, and that someone can tell me what I am doing wrong!
    Tim
    Peter Litwinowicz replied 15 years ago 2 Members · 1 Reply
  • Peter Litwinowicz
    September 12, 2011 at 5:49 pm
    I presume you are using the FxPlug version within FCP and not the AE-compatible version. Otherwise my directions would be different.
    I presume that you might be hitting the problem described here: https://www.revisionfx.com/support/faqs/hostfaqs/fcp_fields/
    Also, Not sure where you are getting Twixtor 4.5 as a first time user… if you are trying out a demo you should be using Twixtor 5.
    Pete
