Activity Forums RE:Vision Effects Problems with Twixter
  • Problems with Twixter
    Posted by Luca Villanova on September 7, 2011 at 2:01 pm
    I used it for the first time Twixter and the result is not satisfactory.
    I recorded with my 7D to 60fps with a 1/2000 sec.
    https://www.youtube.com/watch?v=2Xbl5joqVek
    the result have got a bad effect on the movement of the legs, and a stop a few seconds.
    Thanks for your help.
    Luke
    Luca Villanova replied 15 years ago 2 Members · 4 Replies
  • Pierre Jasmin
    September 7, 2011 at 10:28 pm
    It looks like you have a frame rate setting issue somewhere. We need to know in what app you are using Twixtor to answer as setup for that varies.
    Pierre
  • Luca Villanova
    September 8, 2011 at 8:10 am
    Thank Pierre.
    I use EF CS4 and i have set in TW the exactly same FPS of imput movie, 60FPS.
    Luke
  • Pierre Jasmin
    September 8, 2011 at 8:49 pm
    I assume the movie is actually 59.94 not 60 FPS (if so the value in Twixtor for Input FPS should be 59.94). It shows as 59.94 in the project bin…
    And I assume your comp is something else, e.g. 29.97 or 25 yes? and the rate you are rendering to?
    Would be best you simply enter your email here:
    https://revisionfx.com/support/contact/
    And the automatic response will send you info on how to upload an example (with your AE project) so we can look at it
    Pierre
  • Luca Villanova
    September 9, 2011 at 9:37 am
    HI Pierre i used the link but unfortunately i don’t saved the project.
    Now i redo the project like new, and saved it.
