Activity › Forums › Apple Final Cut Pro Legacy › Problems with Travel Matte – Luma *PLEASE HELP!*
  • Jeremy Garchow
    February 20, 2009 at 3:41 am
    If there really is an alpha channel there, then use travel matte alpha.
    If it really is a true matte with no alpha, put the matte on the bottom (v1) and the fill on top (v2) (you have it the other way around) then change the composite mode of the fill (v2) to travel matte luma.
    Jeremy
  • Jeremy Browe
    February 20, 2009 at 3:47 am
    From one Jeremy to another…thank you so much…that problem was really eating away at me. Thanks again! 🙂
  • Rafael Amador
    February 20, 2009 at 4:55 am
    [Jeremy Browe] “After overwriting the above clip into the timeline, I placed it onto V2 and then added the footage I wanted to replace my white with onto V1. “
    As J. Garchow points, you need to set the matte in V1. The picture where you want to apply the mask must be on top and with the “luma travel matte” mode set.
    rafael
    http://www.nagavideo.com
