Activity › Forums › Adobe Premiere Pro › Problems with transparent image files
  • Problems with transparent image files
    Posted by Filip Szymanski on October 10, 2008 at 11:53 pm
    Hey guys,
    I was wondering if someone could help me out here. I have an image of a wedding ring against a white background. I got rid of the background by turning it transparent in Photoshop. I tried many different formats that support layers but Premiere always says that the file format is not supported (which confuses me because even a .PSD will not import considering it an Adobe format).
    Anyways, what I’m trying to achieve is I have a background matte of green leaves. I want to place the picture of wedding ring (with the transparents background) on top of the matte with the green leaves so I can see the green leaves through the ring where the finger goes.
    Is there any solution to this?
    Dave Friend replied 17 years, 11 months ago 3 Members · 4 Replies
  • Vince Becquiot
    October 11, 2008 at 2:51 am
    PSD files should do the trick.
    Does Premiere even bring up the “footage” option on import. I would merge the layers prior if all you need is the Ring.
    You can also export as Png instead of PSD. The alpha channel is supported by Premiere. Or you can send me a copy of the PSD to look at: vince (at) kaptis.com
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    San Francisco – Bay Area
  • Dave Friend
    October 11, 2008 at 1:32 pm
    Make sure that the file is RGB. If it is CYMK then PPro will not import it and you get a ‘not supported’ error.
    Dave
  • Filip Szymanski
    October 11, 2008 at 4:39 pm
    Thanks, saving it with an RGB profile worked!
  • Dave Friend
    October 12, 2008 at 2:04 am
    You are welcome. Happy I could help.
