Activity › Forums › Apple Final Cut Pro Legacy › Problems with transition dissolves applied to nested clips ever since the last two FCP updates
Kim Rowley replied 19 years, 5 months ago 4 Members · 11 Replies
Kim Rowley
April 2, 2007 at 8:33 amDon’t want to get off topic, but how in the world did you get Boris FX to work? I installed Boris FX 8 to FCP 5.1.2 and have NEVER been able to get the transitions working. Not even with the workaround Boris gives which essentially tells FCP you’re applying a filter when in reality you’re doing a transition. That is you’re going into the Boris transitions through the “back door”. Absolutely no luck here.It’s a shame because that would be an excellent addition to FCP if it worked as seemlessly as it does with M100. Oh well…
Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.1.2, OS X10.4.8
