Activity Forums Adobe After Effects problems with stills only being 1 frame
  • problems with stills only being 1 frame
    Posted by Avril Wallace on August 22, 2006 at 9:14 pm
    Hello, i am having problems when i import a photoshop composition…
    I want to animate the text and photos inside the comp but it is only one frame and I can’t seem to make it any longer by changing the comp size and duration. Please help…I must be importing it improperly, shouldn’t I be able to just pull the size longer?
    thanks for any replies, obviously I am not a practiced user, but im love this program!!!
    Coverbee replied 20 years ago 3 Members · 2 Replies
  • Jack Hilkewich
    August 22, 2006 at 9:23 pm
    In your preferences you can set the duration of the stills you import. It is under the “edit” menu.
  • Coverbee
    August 22, 2006 at 10:02 pm
    Hi
    In your preferences (under “After Effects”) go to Import.
    Change the duration for Still Footage (or make it comp size)
    When your Still is in the timeline you should be able to drag the end of the track to make it longer (that is if the overall composition duration is longer than the still)
    I hope this helps…
    Cheers
