Activity › Forums › Sony Cameras › Problems with Spanned footage over two cards shot on Sony EX3
Micheal Jreisat replied 11 years, 11 months ago 9 Members · 14 Replies
Ian Kibbe
September 23, 2011 at 4:57 pmHey Craig,
Thanks, your posts have been a huge help. So, I’ve done everything you recommend after cobbling together replies to all sorts of XDCAM transfer and Browser posts, but am having this similar problem with a few pesky .smi clips
I’ve made all the folders available, which cleared up some of my incomplete .smi files, but some of them are still incomplete. What’s really odd, is that if I inspect the file in the XDCAM Transfer viewer, it actually tells me where the other clip is.
It reads: “Incomplete Clip. This clip has been split across multiple cards. It continues with 744…etc on (parent folder name)”
Both clips and folders are available to XDCAM Transfer, I can play both in the viewer and I’ve tried selecting both, selecting all, etc. but it won’t connect them.
I’m using XDCAM Transfer 2.10
Thoughts? Thanks a ton!
Craig Seeman
September 23, 2011 at 5:00 pmPlease watch the tutorial I posted above.
Please update to 2.12 -
Ian Kibbe
September 23, 2011 at 7:56 pmThanks Craig.
I’m running PPC, so I can’t go to XDCAM transfer 2.12, but it doesn’t seem like that should be causing this, since your tutorial runs an older version. I’ve followed the tutorial to a T, but no success, still gives me the incomplete listing. I guess I’ll just import as in with in and out points and connect them manually.
Thanks anyway.
Micheal Jreisat
September 14, 2014 at 9:35 amFrom : Michel Jreisat
Dear I have problem w spanned over two cards shot. I lost one of the two cards, I long and transfaire the footage but I have missed the long footage ( incomplete media ) I still have first SXS memory ,
any help to get this ( Incomplete media)
Michel
