Activity Forums Panasonic Cameras Problems with spanned clips
  • Problems with spanned clips
    Posted by James Dow on September 26, 2013 at 5:58 pm
    After years with no problems of any kind with P2 media I’ve recently had several issues. I get the red exclamation mark on spanned clips. They will play in the Log and Transfer window, but they won’t Transfer into the FCP logging bin. This has happened twice in the last week.
    Is this likely a problem with the P2 cards? Any ideas/suggestions?
    James
    JPD
    James Dow replied 12 years, 10 months ago 2 Members · 4 Replies
  • Chris Tompkins
    September 27, 2013 at 12:11 pm
    Hey James,
    Are you transferring all media/cards to the computer first?
    How or what are you using to do so?
    Chris
  • James Dow
    September 27, 2013 at 9:12 pm
    I transfer cards to a portable hard drive using the Panasonic P2CMS software. I create a folder for the production then output the contents of the cards to that folder. I do not keep the cards separate…all of the footage is going into the same folder. I’ve always done it this way and never had problems.
    When I edit in FCP 6.8 I Log and Transfer from the portable hard drive.
    JPD
  • Chris Tompkins
    September 27, 2013 at 9:52 pm
    Have you tried:
    Trash prefs.
    Repair permissions
    Reboot
    I would try that.
    Chris
  • James Dow
    September 30, 2013 at 1:48 pm
    I have not tried that. Thanks for the suggestion.
    JPD
