Activity › Forums › Apple Final Cut Pro Legacy › PROBLEMS WITH SEQUENCES
  • PROBLEMS WITH SEQUENCES
    Posted by David Reichelt on September 5, 2007 at 6:17 pm
    Hi I have a few sequences in one of my projects. When ever I cut and paste some material from one sequence into another one, it wants me to render. I checked the sequence settings and they are the same, so I’m not sure what the problem is.
    Tom Daigon replied 19 years ago 5 Members · 8 Replies
  • 8 Replies
  • Anders Haavie
    September 5, 2007 at 6:45 pm
    Hmm. Sound very strange. Try duplicating the sequense and remove the stuff you don’t need instead. (just an idea how to get around the problem)
    Anders
  • Sherwood Ball
    September 5, 2007 at 7:28 pm
    I’m having the same problem in a workaround.
    Is FCP losing the paths to the original renders?
    G5 Dual 2.5 GHz
    6G Ram OSX 4.8
    Sata drives
    Final Cut Studio 5.1.1, Logic Audio 7.1
    PS CS2, AE CS2
  • David Reichelt
    September 5, 2007 at 7:46 pm
    I’m sorry, upon closer inspection it looks like two sequences are 29.98 frame rates while one has a 29.97 frame rate. Is there a way to change the frame rate with out disaster?
  • Tom Daigon
    September 6, 2007 at 1:10 am
    Yes, it a problem many have come across and Apple has documented. It seems to happen when you dupe a sequence…then at some time power down the computer. When you resume the rendered file are lost and cant be connected.
  • Jhmcf2
    September 18, 2007 at 10:41 pm
    Has apple issued a solution to the problem
  • Tom Daigon
    September 18, 2007 at 11:48 pm
    A little more info or a link might be nice…
  • Jhmcf2
    September 20, 2007 at 9:58 pm
    Sorry for the confusion. My last post was a question. You said apple documented the problem. Did they release a solution to the problem?
  • Tom Daigon
    September 21, 2007 at 1:24 am
    Sorry…my mistake as well. Their solution is a work around, but unfortunately I dont have a link to it.
