Activity Forums Blackmagic Design Problems with SD genlock and laying to Digi
  • Problems with SD genlock and laying to Digi
    Posted by Aaron Neitz on March 13, 2006 at 7:56 pm
    New HD Plus card. Working primarily in SD. Whenever I have genlock plugged into the card, I’m getting occasional hits when laying back to Digibeta. Unplugging genlock and setting Digi to Input Video fixes this, but what could be causing it? A bad DA feeding genlock / reference signal breaking up? Nothing’s changed in a facility except a Kona SD card to the HD Plus upgrade – and the kona never had genlock problems.
    Aaron Neitz replied 20 years, 5 months ago 3 Members · 4 Replies
  • Peter Wiggins
    March 13, 2006 at 9:05 pm
    You’ve referenced the digi? Terminated?
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
  • Aaron Neitz
    March 13, 2006 at 9:20 pm
    Yup. Everything’s done right on a wiring standpont. that’s why I’m scratching my head.
  • Bob Zelin
    March 14, 2006 at 1:47 am
    what brand of Black gen are you using. I hope it’s not an ESE, as this is an unstable unit. AVID Adrenaline’s will never lock to an ESE, so I assume that the blackmagic would have the same issues.
    Bob Zelin
  • Aaron Neitz
    March 14, 2006 at 5:35 pm
    No, it’s a big Textronix multiple sync generator – same on they’ve had in the facility for over 10 years. The only reason I wonder if the card is having problems is that all the other gear in house is fine, and the SD card I had in before locked to that sync no problems.
