Activity Forums Adobe After Effects Problems with scrolling text
  • Problems with scrolling text
    Posted by Austin Ray on November 15, 2006 at 8:52 am
    I’m trying to make a creditlist (scrolling) upwards at the end of a show. The text is scrolling fine, but I get problems with the outcome – it looks like it’s “jumping” and it becomes very flickering. I don’t know how to explain in detail in english, but I’m sure all of you who know this problem about text in motion would know what I mean. Anyone know what to do to make this work?
    What I do to make it a little better as it is is to change the font to suitable, not too thin, fonts and I put on some blur (0.3 of guasian) – it gets a little better, but not much.
    I export as QuickTime Anination (Apple Animation) – because I need the Alpha channel and I import it into a DV-PAL FCP-project.
    I’ve also tried to export uncompressed and BlackMagic 8-bit to make a Preview from DeckLink Controller – same problem.
    (HELP!)
    Jonathan Siler replied 19 years, 10 months ago 3 Members · 2 Replies
  • Mylenium
    November 15, 2006 at 9:16 am
    Make sure you scroll in even multiples of the target playback framerate, e.g. for PAl, which is 25 fps, use 100 pixels per second and so on.
    Mylenium
    [Pour Myl
  • Jonathan Siler
    November 16, 2006 at 2:41 am
    I would recommend using field render in your render settings dialog. That in combination with your blur should help the problem alot. If you’re using a BMD Decklink, lower field first is the way to go, as with DV also.
