Activity Forums VEGAS Pro problems with scan order rendering mov file
  • problems with scan order rendering mov file
    Posted by Aleksandrs Dubanevics on February 9, 2017 at 7:44 pm
    Hi guys,
    So I need to render out .mov file (DV, codec dvcp) so that the scan order is Top Field First, but somehow I cannot do that. It’s either Bottom Field First or Progressive. What am I doing wrong? I tried changing setting etc., but still nothing seems to work to get the Top Field First. Any help?
    John Rofrano replied 9 years, 6 months ago 2 Members · 1 Reply
  • John Rofrano
    February 10, 2017 at 4:27 am
    [Aleksandrs Dubanevics] “So I need to render out .mov file (DV, codec dvcp) so that the scan order is Top Field First, but somehow I cannot do that. It’s either Bottom Field First or Progressive. What am I doing wrong?”
    We cannot tell you what you are doing wrong if you don’t tell us the exact steps that you are taking.
    [Aleksandrs Dubanevics] “I tried changing setting etc., but still nothing seems to work to get the Top Field First. “
    Are you rendering as NTSC DV/DVCPRO or PAL DV/DVCPRO? NTSC is Lower Field First and PAL is Upper Field First.
    I just rendered a PAL DV/DVCPRO QuickTime MOV file as Upper Field First and when I dropped it back on the Vegas Pro timeline is correctly showed as being Upper Field First so it is working as one would expect. As I said, I can’t say what you are doing wrong because I don’t know what steps you have taken or how you have come to the conclusion that the file is not as intended.
    Vegas Pro does not come with a PAL or NTSC DV QuickTime template so you must be creating one yourself. Can you show us a screen shot of your settings? Perhaps then we can see where you’ve gone wrong.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
