Activity › Forums › Adobe Premiere Pro › Problems with rotation and export to DVD Premiere 1.5
  • Problems with rotation and export to DVD Premiere 1.5
    Posted by Oleg Fecanin on August 31, 2008 at 8:56 pm
    I have a clip of 750 x 480. I have rotated the clip about 90 degrees and zoom it in to fit the width. It is still quite sharp, but problem begins when I export it to DVD. I have used 16:9 NTSC High Quality 1 pass (have tested more) and the result is little bit shaky.
    Anyone has experience with this?
    Please advice.
    Oleg
    Oleg Fecanin replied 18 years ago 2 Members · 2 Replies
  • Ann Bens
    September 3, 2008 at 5:42 pm
    Try flicker removal in the field options.
  • Oleg Fecanin
    September 3, 2008 at 7:20 pm
    Thanks Ann,
    I’ll try that. Actually I have found out this: besides the rotation and the scale I had also applied a speed reduction. (90%). All these 3 factors together caused flickering. When I omitted the speed reduction the DVD was burned just fine.
    Now I am going to try it with the speed reduction and with the flicker removal tool.
    Thanks for your help!
    Oleg
