Activity Forums Adobe Premiere Pro Problems with ripple delete and audio keyframes not moving
  • Problems with ripple delete and audio keyframes not moving
    Posted by Glenn Fleagle on July 20, 2009 at 2:23 am
    Hello, i am finishing up a project and have about 5 seconds of blank space at the beginning.
    I want to remove it.
    However, no matter what i seem to try, whenever i move everything, the keyframes that i had set up in the audio portion (the only place i’ve used keyframes) stay where they were.
    The audio moves but not the keyframes.
    I really don’t want to edit all of those keyframes again as it is a fairly big project.
    Can anyone help?
    Metta Xu replied 14 years, 8 months ago 5 Members · 5 Replies
  • Vincent Rosati
    July 20, 2009 at 1:14 pm
    There’s probably a better solution than this, but you could nest the sequence (create a new sequence, and drop the original sequence in the timeline). Than, ripple delete in the new sequence.
    Vince
  • Ann Bens
    July 22, 2009 at 9:49 am
    Your audio keyframes are probably set to track option instead of clip option.
  • Glenn Fleagle
    July 23, 2009 at 1:43 am
    Yes, you are right.
    But, if i change it, all keyframes seem to disappear and i really don’t want to put them all in again. It is a lengthy project and is almost complete. I just want to take a few seconds off the beginning.
    Is there any way to keep them where they are and delete a few seconds in the very beginning of my timeline that you know of?
    I really appreciate all the advice. this site is wonderful and i will try to contribute some answers where i can also.
  • Nigel Gregory
    March 21, 2011 at 12:12 pm
    Hi, Did you ever sort out the problem, why I ask I have a simular issue, whereby I need to insert another title at the beginning but the audio keyframes will not follow the timeline! 🙁
  • Metta Xu
    January 9, 2012 at 3:52 pm
    I’ve got the exact same problem. Doing some trimming but the audio keyframes refuse to move in tandem, a small problem with a big headache. Tried changing option to clip instead of timeframe but then I lose the ability to set keyframes.
