Activity Forums Maxon Cinema 4D Problems with retarget in Cinema 4D R14
  • Problems with retarget in Cinema 4D R14
    Posted by Rolf Tollerud on April 16, 2013 at 11:17 am
    I have a bvh file with the same joints as the target even the the names are the same. When I hide the mesh and retarget from hip to hip everything works as expected, the target figure follow the source exactly. But if I show the mesh (visibility on) I can see that it is horrible distorted.
    What do I do wrong?
    Nebojsa Cekic replied 12 years, 11 months ago 4 Members · 5 Replies
  • Adam Trachtenberg
    April 16, 2013 at 2:06 pm
    You need to align the joints of your C4D rig so they match the alignment of the bvh rig.
  • Rolf Tollerud
    April 16, 2013 at 3:57 pm
    Thank you but i am not able to make it work, the mesh turn to mishmash whatever I do. However I found a workaround. In motionbuilder it works out of the box and I can export and import to Cinema with Fbx. If anyone is interested here is a link to the original C4D file, (a fashion catwalk). I still would like to know what was wrong!
    https://dl.dropboxusercontent.com/u/10255731/V5Catwalk.zip
  • Cactus Dan
    April 16, 2013 at 4:28 pm
    Howdy,
    The joints in the 2 skeletons are not oriented the same. The BVH skeleton has the joints oriented with their Z axes pointing to the next joint down, while the skinned skeleton has all of the joints oriented with their Z axes pointing in the same direction as the World Z axis:
    Adios,
    Cactus Dan
    Cinema 4D R13 Prime
    http://www.cactus3d.com
    http://www.cactus3d.com/Plugins.html
  • Rolf Tollerud
    April 16, 2013 at 5:09 pm
    Thank you Cactus Dan it is really appreciated. It may take me awhile to sort this out there are things i have to do. First how to fix the joint orientation and second, to find out how they could become misaligned in the first place! (because I created the Bvh skeleton from the org figure skeleton). Just want to say thanks while I’m working so you know.
  • Nebojsa Cekic
    October 10, 2013 at 5:41 pm
    Yes, same problem here. Retargeting works from skeleton to skeleton ideally, but mesh after retargeting is rather distorted…and I can’t use Motionbuilder since I’m on OS X. I’ll see if I can sort this out. But it is not clear to me as to why Retarget tab doesn’t work. Everything seems to be Ok – hierarchy & bones orientation is the same….
    Regards to all,
    Nesha
