Activity Forums VEGAS Pro Problems with rendering to WMP foramt
  • Problems with rendering to WMP foramt
    Posted by Morty Aronsen on September 30, 2009 at 7:15 pm
    I`ve been rendering a movie withe WMP template. The result is quite bad, especially the moving texts and the transitions. You can see lines across the picture, and the resolution is bad. What can I do to improve this?
    John Rofrano replied 16 years, 11 months ago 2 Members · 3 Replies
  • John Rofrano
    October 1, 2009 at 12:31 am
    What is the “WMP” template? Do you mean “WMV“? Which exact template name did you use? There are lots of them ranging from really bad web video to high definition.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Morty Aronsen
    October 1, 2009 at 8:59 pm
    I have some problems here, because I can`t get this as smooth as I want. I hope I get some help.
    I picked video for windows (*.avi), and default on that one is template PAL DV. I just want to get a good result on my video, and need some recomendations.
    I also experience some trouble with the project I want to burn with dvd architect. Can I just pick MainConcept mpeg2, and template “dvd architect pal video stream”, without doing any corrections? I want to set the video to “best” and the bit rate to constant 8000 000. I also want to include the audio track. Will I get trouble in dvd architect? (compressions etc? ).
    M
  • John Rofrano
    October 3, 2009 at 1:13 am
    You should not get into trouble with those changes unless DVD Architect doesn’t allow MPEG2 audio for PAL. You’ll have it try it and see.
    ~jr
