Activity Forums Apple Final Cut Pro Legacy Problems with Pro Rez HQ
  • Problems with Pro Rez HQ
    Posted by Itamar Kool on February 10, 2009 at 11:40 am
    The set up is: Pro Rez HQ 50 fps in HD 1280×720.
    FCP gets stuck all the time. I get the spinning wheel for a while and then it sort of releases the stream again. Never had this problem before. Drives are fast enough for this type of stream I would say. It must be something within FCP, my processor…. Also tried without output via my Kona card. Didn’t help.
    Kool En De Anderen
    MAC Pro 8 core/OS 10.5.4/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
    http://www.koolendeanderen.nl
    Itamar Kool replied 17 years, 6 months ago 3 Members · 4 Replies
  • David Roth weiss
    February 10, 2009 at 12:09 pm
    You are assuming that your raid throughput is adequate — why not test read/write speed with the Kona test utility?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Itamar Kool
    February 10, 2009 at 12:22 pm
    I did. Throughput for 1280/720 10 bits with 4 gig file size: read 227 MB/s and write 219,4 MB/s. Wouldn’t that be more than enough?
    Kool En De Anderen
  • Walter Biscardi
    February 10, 2009 at 12:31 pm
    Do you have Premiere Pro CS3 installed on that machine? I would remove any Kona drivers you have installed for PP and see if that helps your playback.
    I know AJA finally released the drivers for that app on the Kona, but I’m curious if that’s causing any issues with ProRez files.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Itamar Kool
    February 10, 2009 at 12:40 pm
    I uninstalled the Aja Adobe drivers. Didn’t help
    Kool En De Anderen
