Activity Forums Adobe After Effects problems with playback
  • problems with playback
    Posted by Piff Aroni on January 17, 2010 at 4:11 am
    I am having problems with playback with after effects. For example, say I am loading some explosions in after effects, when I hit play I see the green bar moving across , but it takes a while for the bar to go, only it doesn’t finish going to the end, instead the bar seems to act like a snake, with a beginning and end, but never fully completes going across, this is stopping me from seeing my footage in realtime after I have applied effects.
    In final cut pro, all I use to do is hit the render command, and it would render. for the most part, for good, unless I did some more editing.
    it plays at 03.2 FPS. This is not the way I have seen After Effects used in tutorials, and I have a quad core mac.
    Joey Foreman replied 16 years, 7 months ago 2 Members · 1 Reply
