Activity Forums Boris FX Particle Illusion Problems with “picking up color” …
  • Problems with “picking up color” …
    Posted by Dennis Fassbaender on April 12, 2008 at 10:45 am
    Hi there.
    I have a problem picking up colors from a layer.
    When i´ve loaded an image- or video file as the layers background and use an emitter (any effect) i whant to correct the colors from this emitter.
    I right-click on the emitter (in the left frame) and click on properties.
    Now the properties-dialog opens.
    Well- now HERE IS MY PROBLEM:
    I whant to pick up some colors from my image from the area where the property-window is placed over. So i “hold” the property-window to move it away from the place of my BG-image to pick-up the color under the windows – BUT:
    that doens´t work. The area where the property-window was is just black! Everywhere i move this window to the background becomes black and i cant see the background image until i close the property-windows.
    What can i do to pickup the colors under the properties-dialog?
    My Hardware:
    P4-3GHz
    1GB-RAM
    Asus-Board
    GForce 7300 GT
    Greets, Dennis
    Dennis Fassbaender replied 18 years, 4 months ago 2 Members · 2 Replies
  • Alan Lorence
    April 12, 2008 at 8:53 pm
    Maybe if you switch to software rendering?
    Or just render a single frame of the stage and open that in another app and grab from that? Or do a screengrab?
    Not sure.
    Alan.
    http://www.wondertouch.com
  • Dennis Fassbaender
    April 13, 2008 at 10:56 am
    I took some shots for you- so you can see what/when is the problem.
    You can see my settings there, too.
    Here are the shots:
    Let me know if you need more informations.
    Greets,
    Dennis
