Activity Forums Apple Final Cut Pro Legacy Problems with Overlays and Freeze Frames
  • Problems with Overlays and Freeze Frames
    Posted by James Dow on May 5, 2008 at 1:29 pm
    When I try to create a freeze frame, or put a lower third Motion file on another track to key, the image turns red. I just switched to a dual Quad Core, and I’m using an AJA I/O box. Any suggestions?
    Thanks.
    Jeremy Garchow replied 18 years, 3 months ago 3 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    May 5, 2008 at 2:16 pm
    You mean the clip itself turns red or you get a red render bar in the timeline?
    Jeremy
  • David Bogie
    May 5, 2008 at 2:36 pm
    Turns RED or displays an error message over a red screen?
    You mean the whole image is replaced by a red screen or the image has a red overlay? Or you’re having trouble with the overlay displays, too?
    You’re probably seeing the alpha. Look in the manual for how to turn it off in the Viewer and Canvas displays.
    bogiesan
  • James Dow
    May 5, 2008 at 2:57 pm
    The clip itself, no render bar.
    JPD
  • James Dow
    May 5, 2008 at 2:58 pm
    Turns red, but no render bar.
    JPD
  • Jeremy Garchow
    May 5, 2008 at 3:06 pm
    [James Dow] “The clip itself, no render bar.”
    Then change your canvas from alpha to RGB
  • James Dow
    May 7, 2008 at 2:06 pm
    The settings are not showing the alpha, although it looks like it is. I drag a motion clip onto the timeline, over another video track and the problem occurs. I dragged a text clip from FCP over the same section of the video track and it looks good…until I add a drop shadow to the text, then I get the same problem.
    James
    JPD
  • Jeremy Garchow
    May 7, 2008 at 2:52 pm
    Any chance you can post a screen shot?
    I have heard of drop shadows giving people fits.
    You have gone up to the canvas and under the third pill looking button you have changed the drop down menu setting from Alpha to RGB?
    Jeremy
  • James Dow
    May 7, 2008 at 3:54 pm
    The drop down setting is RGB. I think I just discovered what the problem is. I’m using an AJA iO, digitizing component out of a DVC Pro deck. The capture preset got changed, so when I started looking at different presets the problem went away.
    JPD
  • Jeremy Garchow
    May 7, 2008 at 4:08 pm
    [James Dow] “The capture preset got changed, so when I started looking at different presets the problem went away. “
    That’ll do it.
