Activity Forums Compression Techniques Problems with my FCP sequence compressing in Sorenson Squeeze
  • Problems with my FCP sequence compressing in Sorenson Squeeze
    Posted by Fredy Schwerdtner on October 15, 2008 at 9:06 pm
    I’m editing some clips in FCP 6 that were filmed in DVCAM-720/480 NTSC Anamorphic (16:9). I will have to delivery everything compressed to be streammed on a website. The webmaster and the owner of the site choose to use the Sorenson Squeeze Soft. and elaborated the settings that I must use.They have choosen for H264 using the Main Concept Codec.
    The problem is that when I export the sequence from FCP, as QT or even as DVCPRO and put it in Squeeze, the movies come compressed with spasms of pixalization. First I’ve thought that it could be because of the settings or the use of that Main Concept Codec because I did a test using the Apple codec and it didn’t happen. A friend of mine did a test for me in his computer using the same settings in my movie and in another one of his library. It only occurs on my videos. What is happening with my sequences ? Is there an incompatibility between that codec and QT or anamorphic videos ?
    PS.: The settings has a Multi pass method and when we change to 1vbr or 1 cbr, it doesn’t compress with the spasms but quality decreases …
    Daniel Low replied 17 years, 11 months ago 2 Members · 1 Reply
  • Daniel Low
    October 15, 2008 at 11:03 pm
    Export as a Quicktime Movie using current settings not as a Quicktime conversion. Do NOT re-compress your movie, especially to another codec.
    This subject has been covered quite a few times in this forum.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
