Activity Forums Adobe After Effects Problems with mpeg in AE CS3
  • Problems with mpeg in AE CS3
    Posted by Jose Noguera on July 11, 2009 at 7:17 pm
    Hi, I have problems with the export from mpeg AE. Does not appear among Las formatting options for rendering.
    This is because?
    Another question, In this case, Which format is more suitable for rendering and then make dvd. Use avi, And then step in to mpeg2 SonyVegas 8, but if you can guide me with another form of direct rendering AE would be good
    If anyone can help me, Are grateful…
    Greetings
    Jose Noguera replied 17 years, 2 months ago 3 Members · 3 Replies
  • Danny Winn
    July 12, 2009 at 4:54 pm
    Hey Jose,
    Yes, Mpeg is an option. After you’ve added your comp to the render que, click the word “Lossless” in the output module. Then another window will appear, at the top of the window it will say “Format” and should have a dropdown menu with several options to output including Mpeg.
    Unless you have a real old version of AE, but I believe that CS3 and 4 have this option.
    good luck.
  • Todd Kopriva
    July 12, 2009 at 7:14 pm
    Are you using a trial version of the software?
    from “Supported output formats”:
    “The free trial version of Adobe After Effects software does not include some features that depend upon software licensed from parties other than Adobe. For example, mocha for After Effects, some effect plug-ins, and some codecs for encoding MPEG formats are available only with the full version of Adobe After Effects software.”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Jose Noguera
    July 22, 2009 at 8:44 pm
    Danny, Thanks for answering my question, But the truth is that I do not see the option mpeg. When you first install the AE CS3 if they had, But then disappeared from the list of formats. Grace for trying to help. Greetings
