Activity Forums Boris FX Particle Illusion problems with moving certain emmiters?
  • problems with moving certain emmiters?
    Posted by Ian Smith on July 14, 2014 at 3:17 pm
    Hi everyone I’m new on this forum, been using PI3 for a couple of years now been doing loads of effects for my movies in the past. I am having real trouble with 1 problem that I need answers for, I’m using a the gunfire emmiters and placed it on the scene where I started it off (easy) but as the scene goes on I want to move the emmiter so it follows the gun on screen but it won’t follow at the correct speed? Now I’ve had the same problems in the past with certain emmiters but found others to replace them that actually follow the lines where I wanted it to go (energyball is one of them that worked perfectly with moving it) which helped me alot there but on the gunfire emmiters they all seem to not be able to follow at the right speed. Is there a setting in the emmiter to get it to go at the correct speed I want to move it at?
    Chears, Ian. 🙂
    Ian Smith replied 12 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
