Activity Forums Apple Final Cut Pro Legacy Problems with media 100 EDL’s working in Final Cut Pro
  • Problems with media 100 EDL’s working in Final Cut Pro
    Posted by Ithicus69 on December 15, 2005 at 10:05 pm
    Im importing media 100 EDL’s into Final Cut Pro, using the Sony 3600 edl which final cut recognizes. i see the clips in the listed in the folder to be recaptured. I select all, and hit “Batch”, which final cut starts to do. The video deck im using is the JVC, JV-BRDV6000UB. The problem is…the timecode for the first clip is 00:30:47:04, but final cut is sending the Deck to the wrong timecode, and rewinding all the way to the beginning of the tape to 00:00:53:00. Now in the clip window all the clips have their media in and out points listed. why is the software and or deck going to the wrong timecode? and is there a solution or workaround to this problem?
    any help is welcome
    Ithicus
    Sean Oneil replied 20 years, 9 months ago 2 Members · 1 Reply
  • Sean Oneil
    December 17, 2005 at 5:18 am
    I think you should try CMX 3600 for your EDL. It’s been a while since I had to do this, so I’m not sure.
    Sean
