Activity Forums Panasonic Cameras Problems with Log and Xfer with P2 to FCP
  • Problems with Log and Xfer with P2 to FCP
    Posted by Bill Mcmilliln on May 6, 2010 at 8:46 pm
    I am having problems getting P2 footage into FCP 6.0.6. Am using Log and Transfer, and have Contents files and Last Clip file. FCP is seeing some clip but not others and one entire card file it says the file structure is invalid even tho it seems to have all the necessary components. Any ideas?
    Bill McMillin
    Steve Eisen replied 16 years, 4 months ago 5 Members · 6 Replies
  • Marcus Van bavel
    May 7, 2010 at 2:59 pm
    You might try Raylight for Mac ($150), it is a lot less picky about the file structure, quicker than Log and Transfer, and also imports your metadata into the bin so you can search and sort on clip info. See https://dvfilm.com/raylight/mac
  • Bill Mcmilliln
    May 7, 2010 at 3:31 pm
    Thanks. I’ll give it a try.
  • Heloise Depocas
    May 8, 2010 at 11:20 am
    I am having the same problems getting P2 footage into FCP lastest version. Am using Log and Transfer, and have Contents files from one card and not the second. It says the file structure is invalid even tho it seems to have all the necessary components. Any other ideas than the 150$ for raylight ? Thanks
    HD
  • Jim Carswell
    May 8, 2010 at 1:05 pm
    Do you have the lastclip.txt file bundled with the contents folder in a single folder?
    Jim
    Jim Carswell
    Spyhop Productions, Inc.
    Savannah, GA
    http://www.spyhopproductions.com
  • Heloise Depocas
    May 8, 2010 at 2:43 pm
    Well, I do now, first my mistake was to load the two cards in the same folder…
    HD
  • Steve Eisen
    May 8, 2010 at 5:07 pm
    That is why you use a program like ShotPut Pro. It does all the work for you and you won’t have problems log and transferring.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
