Activity Forums Boris FX problems with kerning on text window in vegas
  • problems with kerning on text window in vegas
    Posted by William Jochim on March 9, 2011 at 3:21 pm
    When I put text in my text window, most of it is not space right. I don,t mind to kerning it, but when I apply it, most of the letters are not moved enough or moved too much.
    John Rofrano replied 15 years, 5 months ago 2 Members · 5 Replies
  • John Rofrano
    March 9, 2011 at 3:59 pm
    What font are you using? Does this happen with all fonts? It could be a font problem.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • William Jochim
    March 9, 2011 at 5:48 pm
    It is a problem on all fonts
  • William Jochim
    March 9, 2011 at 9:37 pm
    I found the problem, I had ” fixed width” turned on. I turned it off and everything is fine.thank to you all.
  • John Rofrano
    March 9, 2011 at 9:41 pm
    [william jochim] “It is a problem on all fonts”
    That’s odd, I’m not seeing a problem like that.
    When you say, “…when I apply it, most of the letters are not moved enough or moved too much” could it just be that the extrusion is too high and you need to lower it a bit? Could you post a screen capture of what you are seeing?
    ~jr
  • John Rofrano
    March 9, 2011 at 10:08 pm
    [william jochim] “I found the problem, I had ” fixed width” turned on. I turned it off and everything is fine.thank to you all.”
    Good spotting! That would have been extremely hard to diagnose without a snapshot. lol. Glad you figure it out.
    ~jr
