Activity Forums Apple Final Cut Pro Legacy Problems with jerky motion in clips
  • Gunner Jones
    May 19, 2005 at 8:03 pm
    Well, if you have long frames, your drives are too slow, too full or your clips are too long. Recall that Apple does not recommend external FireWire drives. You might try capturing to the internal drive instead.
    Also toss your Prefs, do an audio mixdown and see if that helps you.
    Gun
    O&O-Gunner Productions
    FCP-Avid-After Effects
