Activity Forums Maxon Cinema 4D Problems with IvyGrower Plugin.
  • Problems with IvyGrower Plugin.
    Posted by Chris Wood on April 24, 2012 at 1:22 am
    Hello, for anyone familiar with this plugin, I am having some serious problems with it.
    It just will -NOT- work correctly.
    I create an object in my scene, make it editable, apply the IvyGrower plugin to it. Choose an area to grow, click grow and instead of growing some branches that snake up my object, it grows either 0, 1 or 2 branches, then just stops.
    I have tried reinstalling the plugin several times, different objects, different settings, default settings and different locations on the object. Nothing is working right.
    Help! Please 🙂
    Martynas Kilius replied 9 years, 4 months ago 4 Members · 4 Replies
  • Chris Wood
    April 24, 2012 at 9:26 am
    This can be deleted, I figured it out 😉
  • Scyld
    March 12, 2014 at 3:04 pm
    hey, i have the same problem – it won’t generate branches… can you tell me how you fixed it?
  • Didier Fereaux
    November 1, 2014 at 11:28 pm
    I am having the same problem, using the right version of C4D for the plugin (r13 for r13) and no branches generate.
    Deleted, installed, deleted, installed, not working…
  • Martynas Kilius
    May 25, 2017 at 11:01 am
    I don’t know if this still helps but I found the solution.
    On the “General” tab try activating “use units” checkbox.
