Activity Forums Apple Final Cut Pro Legacy Problems with importing MFX files to FCP
  • Problems with importing MFX files to FCP
    Posted by Nickemp on July 20, 2007 at 11:57 am
    I am unable to import MXF files into my FCP.
    A warning comes up when i try to open the files in the P2 import window: “-has invalid directory structure. Please chose a folder whose directory structure matches the supported media”.
    I have followed Shane’s tutorial and installed the driver. The MXF files are on my Fat32 formatted external hard drive – they came from HVX200 via a PC. They were shot in 25p at 50fps. I am working on a MacBookPro using FCP v5.1.4.
    Is there an extra bit of kit I need to buy/install to import these files? Has anyone else had this problem?
    Nickemp replied 19 years, 2 months ago 4 Members · 5 Replies
  • Christopher Tay
    July 20, 2007 at 1:48 pm
    You need to navigate to the CONTENTS folder in the FAT32 external hard disks, or one folder above it. You cannot rename the CONTENTS folder, which contains the subfolders for VIDEO, AUDIO…etc from the original P2.
    -chrispy
  • Matt Gorney
    July 20, 2007 at 1:56 pm
    We also import our P2 footage into a PC and then
    to the Mac. What we’ve found is that just copying
    the files from our PCMCIA card slot reader
    sometimes doesn’t work. Don’t know why.
    Our solution was to buy the P2 Genie software and use
    that interface to copy files into a folder in our PC.
    We make a folder and direct the P2 Genie to copy there.
    Then I copy the folder to the Mac and all
    is well. The P2 genie software is like 30 bucks, so it’s
    worth it.
    Hope that helps,
    -Matt
  • Nickemp
    July 20, 2007 at 2:25 pm
    “You need to navigate to the CONTENTS folder in the FAT32 external hard disks, or one folder above it. You cannot rename the CONTENTS folder, which contains the subfolders for VIDEO, AUDIO…etc from the original P2.”
    – The DOP named each contents folder as Drop 1, drop 2…etc as they were downlaoded from camera. I then put these with their respective .txt files into a new folder as suggested in the tutorial – are you suggesting that this will cause the files not to be read?
    Nic
  • Shane Ross
    July 20, 2007 at 3:36 pm
    Did he RENAME the Contents folder to DROP 1, DROP 2? Or did he make new folders called DROP 1, and put the CONTENTS folder and txt file in there?
    You cannot rename the Contents folder to ANYTHING if you want it to import properly.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Nickemp
    July 20, 2007 at 5:09 pm
    Yes, it now works, thank you all so so much !!!!
    I have just renamed them all drop 1, 2, etc.. files as contents within the subfolders I made and it now works.
    Happy editing this weekend it is … 🙂
