Activity Forums DaVinci Resolve Problems With Importing Aaf into resolve. From avid
  • Problems With Importing Aaf into resolve. From avid
    Posted by Jesper Lundstrom on June 1, 2013 at 5:03 pm
    Hello I have a new exciting problem in my avid davinci workflow.
    In my davinci project I have Red files, and some quicktime animation files.
    Well my workflow is like this i first imported all red files in davinci and then exported them as dnhd 36 to avid.
    Well the problem starts on the way back to davinci.
    when I import the aaf to davinci I get 13 video tracks instead of one, and i dont know how to fix this.
    My avid sequence only has 1 video track no audio and no effects, still the aaf in davinci producese a timeline with 13 video tracks.
    Does anybody know why this happens?
    Laco Gaal replied 13 years, 3 months ago 2 Members · 3 Replies
  • Laco Gaal
    June 2, 2013 at 11:37 am
    if you have only one timeline, and it doesn’t have speed ramps, try EDL.
  • Jesper Lundstrom
    June 2, 2013 at 3:11 pm
    Ok. Well avid project is filled with like 30 timelines but I only tried export Aaf from one.
    And it was clean, only video track and no effects.
    I did find another solution though to make it work for me but not into davinci. But I will try to solve this cause We use the davinci workflow in my school.
    What other Edl can i export from avid than AAF?
    If anyone is interested my other way arround that I took, was to export an Aaf from my sequence and consolidate the media into a folder on computer from avid.
    Then I took my files and put in a new project(in symphony) and Relinked my dnxhd files directly to r3d instead. Then all my other material that came from after effects i batch imported.
    For this time I will grade in symphony though cause Ive got more files thats waiting on coming in and I dont trust the davinci workflow for now.
  • Laco Gaal
    June 2, 2013 at 4:15 pm
    AAF is not EDL, they are separate things. EDL supports less effects and transitions you can read about it in the Davinci Manual.
    As for the import, the Manual – from page 184 – details the process.
    But as far as I can tell it shouldn’t be a complicated process..I don’t know AVID at all, but I was always able to export a linked AAF and import it to Davinci without any problem.
