Activity Forums Blackmagic Design Problems with HD in FCP with Decklink Extreme
  • Problems with HD in FCP with Decklink Extreme
    Posted by Paul Jones on July 10, 2009 at 9:53 pm
    I hired a JVC HM100 camera today
    My record setting was 1920/50i HQ PAL
    Playback on the viewfinder is fine
    Playback in FCP is fine
    But the picture on the external monitor is all jerky and edgy, especially on moving shots.
    This is the first time I have worked with HD in FCP.
    I am monitoring with a Decklink Extreme HD via HDMI
    Any help really appreciated
    Joshua Helling replied 17 years, 1 month ago 3 Members · 3 Replies
  • Margus Voll
    July 12, 2009 at 6:42 am
    Hi.
    You might output interlaced material to LCD TV or you have down scale enabled.
    Margus
    https://iconstudios.eu
  • Paul Jones
    July 12, 2009 at 8:22 am
    I am going to check this when i’m back in the office tomorrow.
    People are saying that it should be a setting problem with either FCP or the Extreme card.
  • Joshua Helling
    July 14, 2009 at 6:05 pm
    The only setting you should need to worry about is to make sure that you have the proper easy setup selected. Start a new project and make sure you are using the Blackmagic HDTV 1080i 50 (codec) project setting. This should set the project up correctly.
    Then try re-importing your footage and see if it looks right then.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
