Activity Forums DVD Authoring Problems with Handbrake
  • Problems with Handbrake
    Posted by Sejin Kim on November 10, 2016 at 2:07 am
    I am trying to pull off footage from a DVD. There are two folders on the DVD: OpenDVD and the standard VIDEO_TS. When I try to use Handbrake to pull that footage off, it pulls off the first 30 seconds or so flawlessly, then simply stops and calls the encode job done. It sees that there is 33 minutes of footage (which is correct), but it only encodes the first 30 seconds.
    I’ve tried on both a Mac and a PC, both running the latest version of Handbrake, but all with the same results.
    Any suggestions? (I’d prefer to use Handbrake, although software suggestions are acceptable)
    Jesse Simon replied 9 years, 9 months ago 3 Members · 4 Replies
  • Alexander Kallas
    November 10, 2016 at 9:28 am
    You need another App, Handbrake won’t do it.
    Cheers
    Alexander
  • Sejin Kim
    November 11, 2016 at 12:05 am
    Do you mind sharing your favorites?
  • Alexander Kallas
    November 11, 2016 at 8:26 am
    Start with ” Mac the Ripper”
    Cheers
    Alexander
  • Jesse Simon
    November 19, 2016 at 7:47 am
    Recommend a Handbrake Alternative to you. I found this solution just because the HandBrake only rips part of my DVD. And this page list the problems you may encounter and you are able to find solution here.
