Activity › Forums › Adobe Premiere Pro › Problems With Footage
  • Problems With Footage
    Posted by Emily Backman on August 24, 2011 at 12:54 am
    I’m using CS4 and am having major difficulties. I am trying to put together a music video that will be viewed on the web.
    My first question is:
    What sequence presets should I use for the highest quality of video. I have attempted to start in various selections of NTSC and HDV, but always have the same results. The footage is jumpy/choppy. I can’t even tell if it is in real time or not. The audio doesn’t concern me as I have to lay the footage over the song’s audio file (which works perfectly every single time.)
    To further complicate the situation:
    The footage comes from two separate cameras. I’ll just jot down the stats of each.
    Camera #1:
    .MOV clips
    1280×720
    29.97 fps
    Camera #2:
    .AVI clips
    1280×720
    24 fps
    (Camera #1 was shot in 19.97 fps with the idea that the footage will be slowed down).
    I have already run several clips from the second camera through AE in an attempt to create a pulldown and bump the frames to 29.97 fps. My thinking was to have a consistent frame rate to solve this issue. Of course, nothing seems to have no effect on quality of the playback in Premiere.
    Am I not using the right presets? What can I do to fix this problem?
    Vince Becquiot replied 15 years, 1 month ago 2 Members · 3 Replies
  • Vince Becquiot
    August 24, 2011 at 3:06 am
    Hi Emily,
    If most of your footage is HDV, by all means create an HDV sequence. Keep in mind that the type of sequence you pick will not affect the quality of your export.
    You haven’t mentioned your computer specs and drive type. My guess is that it could be a combination of both.
    For drive, you will likely need a nice RAID array, especially if you are running multiple tracks of footage and audio.
    I think the best approach at this point is to throw all your footage in Adobe Media Encoder and convert to a low bit rate format like DV, edit with that, and replace in the project panel when you are done.
    The frame rate however should be solved prior to starting since interpreting afterward will mess up your edit timing.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Emily Backman
    August 24, 2011 at 5:54 pm
    Thank you for the response Vince.
    I must admit that I although I have over 3 years of experience using the Adobe programs, I always using a specific computer and a specific camera; creating my projects with ease and familiarity. Now I am using a totally different computer that only recently had Adobe installed on it and footage sent to me from two cinematographers. (frame rate issues previously discussed.)
    The computer that I am using has the following stats:
    Intel Quad core
    Windows 7 ultimate
    4gb ram
    500 watt power
    Graphics card: Radeon HD 5750
    If you have any suggestions on how to upgrade this computer to be an efficient editing machine, please let me know. From what I know…it was designed to be a massive music storage device with good graphics for playing video games.
    Are you suggesting that I convert the original footage to DV for editing purposes and once my project is complete, to trade out the lower quality for the original HDV footage and export? What is the success rate of this type of process? I’ll do it if it means I can complete this project.
  • Vince Becquiot
    August 24, 2011 at 6:26 pm
    Hi Emily,
    Here comes a looooooong post, you can tell I’m waiting for a client…
    To the most urgent question, yes converting to DV would get you a fluid edit. The caveat is that it’s not HD, so you will not be seeing full quality while editing.
    The process I would recommend:
    1 – Open Adobe Media Encoder, import and convert all the footage to DV widescreen. (Note you could do a test with 4Mb/s H.264 and see if you are able to edit real time)
    2 – Create an HDV or a desktop sequence with the desired resolution and frame rate (Go to the custom tab if needed). If you want full HD, it’s 1920×1080 Square pixels (desktop mode)
    3 – Bring in the DV converted footage and do a quick test. Drop it on the timeline, right click scale to frame size if you want to see it at full frame, do a couple cuts. Then go to the project manager and replace the footage with the original, make sure everything looks good (and it should, especially since you are dealing with separate audio).
    4- Now do you edit in DV and replace at the end. You could also set your preferences to scale to frame size prior to importing the DV footage if you want to avoid doing it for every clip, but that could mess things up if you are bringing in images as well. You would get a quality hit with zoom ins for example.
    Onto your hardware questions. If you do, or plan on doing a lot of editing, some things would likely need to be upgraded. For one, your RAM should at least 8 gigs, 12 Gigs recommended, especially if you are running a 64 bits OS. It matters more if you upgrade to CS5.
    For drives, it’s going to be expensive, but I wouldn’t even be editing without a nice drive array. A couple of streams of video can easily overrun the fastest single drive, that’s without including the overhead needed by the OS and cache from Premiere itself.
    If you are doing After Effects export, you’ll be dealing with uncompressed footage and that’s a real headache.
    The cheapest “great” array I can recommend is the HDElement from Caldigit (looking at about $1800.00 with drives and taxes) for 4 Gigs.
    Great support, very, very fast, and reliable system. I tried cheaper stuff and it just doesn’t compare. You also get the added safety of RAID 5 allowing a drive to fail.
    All of this can get expensive and it depends on how much you are willing to put up with, but if you have a client in the room… well you want something that just works 🙂
    Cheers,
    Vince Becquiot
    Kaptis Studios
