Activity Forums Apple Final Cut Pro Legacy problems with external esata drive need hardware advice
  • problems with external esata drive need hardware advice
    Posted by Roli Rivelino on May 18, 2009 at 3:33 pm
    I am having problems running my external drive via esata, I have a Western Digital ‘my book’ 1TB (mac specific). I’m connecting up via a Lacie PCI express card with 2 esata ports, due to the advice of the person who sold me the machine I bought the cheapest Lacie card (£39) however it has never worked properly.
    I’ve updated the drivers direct from the Lacie site and I have partitioned the drive (1 partition) to a GUID format (mac os extended Journaled), but Final Cut is still crashing and the drive is still behaving erratically anytime I connect via esata (fine via firewire).
    Does anyone know a good reliable PCI card or even another way to connect via esata?
    aka Newbie Wan Kenewbie. “I will get over my manualaphobia, one day at a time.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external Seagate FreeAgent eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Roli Rivelino replied 17 years, 2 months ago 6 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    May 18, 2009 at 3:49 pm
    Sonnet, CalDigit…both make great eSATA cards.
    Now you see the danger of buying SUPER CHEAP stuff. YOu get what you pay for.
    Shane
  • Rob Grauert
    May 18, 2009 at 3:51 pm
    I don’t have an esata card yet, so I don’t even know if the card is the problem, but if it is, I read that Sonnet makes some good esata cards.
    https://eshop.macsales.com/item/Sonnet%20Technology/TSATAIIE2P/
    Robert J. Grauert, Jr.
  • Chadwick Chennault
    May 18, 2009 at 3:57 pm
    You may also check to make sure that all of your old drivers are uninstalled. Look in Macintosh HD->System->Library->Extensions. Throw away anything that says SiliconImage or begins with SIL. Then reinstall the latest drivers.
  • Rafael Amador
    May 18, 2009 at 4:01 pm
    Hi Roli,
    I’m working since more than one year with the LaCie, and not a single problem.
    Make sure that the driver you are installing is the “Siliconimage 3132r5”.
    rafael
    http://www.nagavideo.com
  • Roli Rivelino
    May 19, 2009 at 5:29 pm
    OK, thanks for all of that. I’ve done the check that Chadwick suggested and I can see a few things, I just want to double check what to throw away (if anything).
    I have:
    Siliconimage3132.kext
    Siliconimage3132r5.kext
    should I get rid of the 3132 and keep the 3132r5?
    thanks
    System
    8Gb RAM
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Firestore FS-100
    May 19, 2009 at 8:49 pm
    Personally, I would get rid of both and start from scratch.
  • Tony Brittan
    June 2, 2009 at 2:10 am
    Hey! Did you ever get this sorted out? I’m having trouble with a new Pyro A/V Turbo eSATA. The .kext driver file that was on the cd (I’m on the iPhone so I can’t see your post while answering but it was the one that you had but without the “r5” on it) would install but in system profiler it had the card info and said no driver installed. After talking to tech support And getting nothing accomplished, I found this post and Rafaels link led me to the other driver. I installed that after thrasing the other one and now system profiler show the card, and that the driver is installed but I can’t get mr g-raid 3 or 2 other drives (both 1tb eSATA) to show up.
    This particular card has 4 ports…2 inside & 2 external…but is setup to use the 2 internal by default and you have to change the jumpers to switch it to the external. I did that and installed it both ways to no avail.
    Why would the card show up and the driver show as installed and it not work? Hhhmmmm
    Mac Pro octo-core
    4gig ram
    Mxo2
    10.5.7
    I think that’s all you need to know about my system for this question. Lemme know. Prolly should’ve just gotten caldigit or something but trying to make this work because I’ve hit a couple projects to get rollin
    Any help any of you can give would be appreciated!
    Tony Brittan
  • Roli Rivelino
    June 2, 2009 at 8:59 am
    I’m sorry I can’t help, I didn’t get it sorted, welcome to the wonderful world of Apple Crap.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Tony Brittan
    June 16, 2009 at 11:42 am
    I did get it sorted by the way! Buy a CalDigit card. They write their own version of the drivers and the cards are geared towards Mac. FASTA 2 port eSATA card is what I got and it works awesome!
  • Roli Rivelino
    June 16, 2009 at 5:01 pm
    cool thanks, I’ll try that
    System
    8Gb RAM
    Equipment
    Firestore FS-100
